2008-09-03 09:56 PM - last edited on 2023-05-23 04:59 PM by Rubia Torres
2008-09-03 09:59 PM
2008-09-04 03:30 AM
kevin wrote:Try using the Attribute Manager to Overwrite the Archicad layer from your new file into the existing one.
I was able to merge the weird file into a new file I created and had deleted all but the ArchiCAD layer in it. Once I merged, anything that was on the old "building" layer was on the ArchiCAD layer. There was however a "building" layer now in the file, which I was able to delete. The problem is I lose all my viewsets and I am well into CDs so I don't want to recreate everything so this isnt so much a fix as an interesting tidbit of info to go along with it.
2008-09-04 05:21 AM
2008-09-04 04:12 PM
2008-09-04 04:21 PM
2008-09-05 11:34 AM
kevin wrote:Don't merge.
Anyone run into this? Know a fix?
2008-09-05 06:13 PM
2008-09-08 03:41 AM
Dom wrote:I believe so. Have you tried using the Xref Manager?
I typically bring .dwg's in as placed drawings. Problems begin when I explode them.
Is exploding a .dwg file inserted using the "Drawing Tool" the same as a merge?
2008-09-08 05:39 AM
