aryastark
Strange wall intersection problem!
Hey,
i am adding 2 wall to another 2 wall but in suddenly intersect with it's equivalent on the higher priority wall. i couldn't find out why. can you help?
details:
these 2 walls should extend to the corner. ok... let's do it...
uhm! they intersected with their extensions. but why? let's check material priority...
ok. material priority says the outer walls should be priority and the interior walls (with air gap) shouldn't appear on top of the outer walls.
let's check layers...
outer walls have higher priority again... so why????
i want it should show like here:
but not with "bring forward. i want it must cut when touch the outer wall.
because it doesn't show correct in 3d & real 2d:
Ver: AC23
Operating System: Windows 10 64-bit
Processor: Intel(R) Core(TM) i7-6700HQ CPU @ 2.60GHz (8 CPUs), ~2.6GHz
Memory: 16384MB RAM
Card name: Intel(R) HD Graphics 530
Chip type: GeForce GTX 960M
1 Solution
DGSketcher
Legend
If the reference lines don't meet then AC won't process a connection in the normal way, so the walls will just occupy the same space. Sometimes even when they meet getting things to display properly can be a pain, in these situations you can produce a Complex Profile column to correctly display the connection.
Another option would be to offset the solid wall reference lines so they don't meet in their corner and see if you can adjust them to the required connection point on the cavity wall. Unfortunately you may find they try to auto connect to the cavity wall depending on layer and connection settings.
Go to post
2 Replies 2
Miha_M
I guess bring to front / send to back display order could help, as you don't seem have intersecting, but overlapping elements. This is not how it should be done.
Sometimes the GS Help Center or a simple web search can give you advice on how to use Archicad.
This one belongs to basic layer functionality.
https://helpcenter.graphisoft.com/user-guide/76242/
Switching the wall reference line side could help also.
| Archicad 4.5 - 29
DGSketcher
Legend
