2007-08-06 08:03 PM - last edited on 2023-05-23 05:06 PM by Rubia Torres
2007-08-06 08:18 PM
2007-08-07 12:23 PM
TomWaltz wrote:I've noticed. OK - I know very little about ArchiCAD, this may be perfectly obvious to everyone else but me:
You don't. The steel sections are built into the Object library already.
2007-08-07 02:37 PM
Petri wrote:I was just about to answer your question. They are all easy tasks... until I saw that little comment. I wasn't trying to be sarcastic or caustic at all. I was just answering your original question.
How do I make the steel section beam Library Object to be in an angle (vertically) and have its ends vertical as they would be with the Beam Tool?
In addition, how do I make it default that an Object Library Beam goes into IF-class beams? The object I'm looking at has no IF-class whatsoever ("Undefined").
I'm not here to start another argument, but comments like "you don't" are simply annoying. A defence mechanism for fundamental flaws in one's religion? (Right, I did it again... bugger...)
2007-08-07 04:07 PM
TomWaltz wrote:I don't think so. I've established that ArchiCAD cannot do certain things that are essential to my work and that the Defenders of Faith will fiercely attack anyone who questions the doctrine.
Maybe you can find someone else to help who will be less annoying to you.
2007-08-07 05:14 PM
2007-08-07 07:05 PM
Petri wrote:Hmmmmm ...TomWaltz wrote:I don't think so. I've established that ArchiCAD cannot do certain things that are essential to my work and that the Defenders of Faith will fiercely attack anyone who questions the doctrine.
Never mind. I'll get the job done with software that does not require a membership of a Church and adherence to its arcane and ridiculous rituals.
2007-08-08 12:14 PM
TomWaltz wrote:It is symptomatic to a cult that "you don't" and "you do" in one.
Right... you can't figure it out, so it can't be done... you don't like the way someone answered your question (and use a software that does not work the way your old one did), so we're a cult...
2007-08-08 12:19 PM
Just look into the parameters of the steel beam, and it will be obvious. The end cutting planes angles are pretty obvious, even if you refuse to learn.Thank you very much for your encouraging and ever-so-positive attitude! The other patronizing guy calls himself Guru, so you must be either Buddha or Vishnu.
2007-08-10 07:50 AM
Petri wrote:At the cost of endangering my life, I will reveal the secret of initiation:
No, they are not obvious. I'm sure they are obvious to the Initiated & Blessed, but not to us Pagans.
