yesterday
Suddenly, the outline of wall as disappeared.
Question
https://youtu.be/vYCDJQWsEaQ
Archicad file
https://www.dropbox.com/scl/fi/cb5lv4b1wvfbrurckn4x5/carpentera_hidden_column_line.pln?rlkey=vxgd6zz...
Operating system used: Windows 11 24H2
yesterday - last edited yesterday
The position of the column is affecting how the wall trims.
This is just a guess without testing, but check your wall composite settings to see if the end lines are turned on.
This image is from 25, but 29 should be similar.
