I think that Archicad has lots of similar problems that should by now have been sorted. If I have a new slab abutting an existing slab, and put a tiled fill as a thin slab over, the joint between the slabs will show through. The joint should, of course, be obscured by the floor finish. We get round it by moving the slab to the back and the fill to the front. Floor and window sills should obscure floor and wall edges - but they often don't.
The obscuring of one solid element by another should happen by default. If users want something different, they could change settings.
Maybe it happens because Archicad solids are not really solids - they only appear solid because the software makes it seem so. Is this statement correct?
Cornelis (Kees) Wegman
cornelis wegman architects
AC 5 - 26 Dell XPS 8940 Win 10 16GB 1TB SSD 2TB HD RTX 3070 GPU
Laptop: AC 24 - 26 Win 10 16GB 1TB SSD RTX 3070 GPU
