Hi there,
As Matthew pointed out, there is no direct native analog tool in ArchiCAD for that. You can do it somehow manually with the Morph tool, but that would require a bit of patience.
On the other side, there are a couple of objects developed by a spanish guy, Jose Gemez... pretty cool, yet not perfect.
You may achieve similar results with these. follow the links below to their web sites ( In spanish) to get a better idea if they work for you.
http://garquitectos.wordpress.com/tag/dragon/
http://www.garquitectos.es/index.php/foro/5-gdl-objetos.html
Good luck!
P.D. I will post a couple of screenshots for the Morph divide surface procedure later...
Nando Mogollon
Director @ BuilDigital
nando@buildigital.com.au
Using, Archicad Latest AU and INT. Revit Latest (have to keep comparing notes)
More and more... IFC.js, IFCOpenShell
All things Solibri and BIMCollab
