2005-09-15
03:56 PM
- last edited on
2023-05-26
03:29 PM
by
Rubia Torres
2005-09-15 05:45 PM
2005-09-15 05:56 PM
2005-09-15 06:36 PM
2005-09-15 07:16 PM
2005-09-15 07:16 PM
2005-09-15 07:28 PM
Weston wrote:I think his idea was only to edit some parameters while leabing others alone. Favorites, like the syringe, apply to all parameters.
make a favorite for every tool setting you want.
when you want to "inject" properties into a placed object, use the favorites pallette to set your current defaults to what you want
inject the placed item.
Does that work? Just thinking off the top of my head - haven't tried it...
Wes
2005-09-15 08:47 PM
Favorites, like the syringe, apply to all parameters.Actually we can exclude some parameters from our favorites through the Favorite Preferences. Wish we could do the same for transferring with the eyedropper/syringe. Even better would be profiles, as mentioned by oreopoulos.
2005-09-15 09:19 PM
Link wrote:that is kind of true. You can only include/exclude common tool parameters, like width or height, not the internal object parameters like window sill settings or door frame settings.Favorites, like the syringe, apply to all parameters.Actually we can exclude some parameters from our favorites through the Favorite Preferences. Wish we could do the same for transferring with the eyedropper/syringe. Even better would be profiles, as mentioned by oreopoulos.
2005-09-15 09:52 PM
