T-intersection on facades
Hello all
Is there a way to get rid of the vertical line on the facade while keeping the plan intersection clean? I tried increasing priority for the facade walls but it rendered floor plan intersections incorrect.
15 Replies 15
Rod Jurich
Geoff wrote:
Any news on the fabled magic wall healer Rod?
Greetings Geoff, go to 4D Library
How is the skiing?
Rod Jurich
AC4.55 - AC14 INT (4204) |  | OBJECTiVE |
SeaGeoff
Ace
Thanks Rod. I have the object but have yet to play around with it.
Haven't been skiing yet. Waiting for more snow. Cold enough though, -8°C here at sea level.
Regards, Geoff Briggs
I & I Design, Seattle, USA
AC7-29, M1 Mac, OS Tahoe
Graphisoft Insider's Panel, Beta Tester
Rod Jurich
Geoff wrote:
Thanks Rod. I have the object but have yet to play around with it./...
All credit goes to Ben Cohen, all his creation
Rod Jurich
SeaGeoff
Ace
Thanks to Ben then.
Ben Cohen
Thanks Geoff, but the part is nothing special, just a wall end that masks the very corner of the wall. All of about 30 lines of code.
The problem is you need to temporarily move the walls before you can apply the wall end. Because of this I have never really promoted it in the 4D Library.
I think Rod might be the only person I know that actually uses it .
Ben Cohen
Mac and PC
Archicad (Latest Version) aus
www.4DLibrary.com.au
Rod Jurich
Ben wrote:
/..The problem is you need to temporarily move the walls
before you can apply the wall end./......
Only one additional step is easy and solves all 3D woes.
Apart from this fact you may need to swap the side it is attached
to and all this is so much quicker than patches, etc.
And move the wall the wall end follows. so no 3D to fix when a wall is moved.
I use it most on renovation work when wall reference lines
are sometimes difficult to meet in all situations.
Solves all sect/room elev situations because GS has yet to fix this long standing wish.
Rod Jurich
