Has anyone had any success in using the Morph tool to taper steel beams.
In an upcoming project, we will more than likely have a tapered portal frame, ie the depth of the leg and rafter is less at one end that at the other. The leg might be 500mm deep at the floor and widen out to 750mm deep at the knee, and then the rafter would be 750mm at the knee and taper down to 450mm at the apex/ridge.
Obviously this cannot be extruded, but am wondering if it is possible to do this with the Morph tool, by firstly extruding a portal frame, and then Morphing it and adjusting things to get the required dimensions.
Thanks
Ian C
