2004-07-07 01:35 AM
2004-07-07 03:26 AM
2004-07-07 11:37 AM
2004-07-07 06:30 PM
2004-07-07 06:39 PM
2004-07-07 06:44 PM
John wrote:ok - i get it now: because you're in as 'view only' you cannot modify and save the changes of those modified windows! so rebuilding a section/elevation constitutes a change that can't be saved: archiCAD therefore forbids it from even happening. this is a bug big time. i'm surprised nobody has noticed this before.
This error is interesting. If I lower the wall in my share (exclusive access) after sending and receiving changes the wall reports the correct, new height on the the view only computer and even displays the grips at the correct height. It just displays incorrectly in section/elevation 3D etc.
2004-07-07 07:48 PM
2004-07-07 11:42 PM
i get really annoyed when i'm in a file as 'view only' when i can't even change the group/suspend group toggle, (for copying grouped elements out of the file to paste somewhere else), if the file has last been saved with groups off.Sounds like "View Only" is rather literal. You can "only view," not copy, not modify your environment, and not rebuild.
