2006-12-30 06:08 AM
2006-12-30 04:04 PM
2007-01-01 09:18 AM
2007-01-01 03:54 PM
2007-01-01 04:00 PM
2007-01-03 10:23 AM
David wrote:Thanks David that worked, My Library report was turned off that's where I missed out.
Srinivas:
Another place to check is your Material Settings. The Vectorial Hatching (which is working in your elevation) is set in one pane, the Texture (which you are missing in your 3D window) is set in the bottom pane. This could also be due to the textures not being in the loaded libraries, in the Textures pane you will see “Not available in loaded libraries”.
HTH
