Display malfunction of Graphisoft ID dashboard
Learn more
Srinivas
Textures not visible
Dear all,
I am working on a project using US Library(downloaded from http://tr.graphisoftus.com) on ArchiCAD 10 Int. The problem is that ArchiCAD is not displaying the textures correctly only the color is applied to the objects but not the image attached.
When I take an elevation with Vectorial 3D hatching its showning perfect. I am in Open GL - Shading mode only while viewing the 3D.
Can someone help?
Thanks in advance,
Srinivas.
www.bimvizstudio.com
ArchiCAD Service
ArchiCAD since v9 to latest
Mac, Windows 11
5 Replies 5
David Maudlin
Srinivas:
One thing to check: go to the 3D Window Settings dialog box, and with 3D Engine set to OpenGL, click on the Options… button. In the OpenGL Options dialog box, see if Textures is checked.
HTH
David
David Maudlin / Architect
www.davidmaudlin.com
Digital Architecture
Srinivas
Happy New Year David..
The Option is already ON!!!!
ArchiCAD Service
Mac, Windows 11
Does the texture render properly with either the internal engine or LightWorks? (I assume that you have checked that the material does have a texture associated to it.) Does the texture work when applied to something else?
David Maudlin
Srinivas:
Another place to check is your Material Settings. The Vectorial Hatching (which is working in your elevation) is set in one pane, the Texture (which you are missing in your 3D window) is set in the bottom pane. This could also be due to the textures not being in the loaded libraries, in the Textures pane you will see “Not available in loaded libraries”.
HTH
David
Srinivas
David wrote:
Srinivas:
HTH
David
Thanks David that worked, My Library report was turned off that's where I missed out.
ArchiCAD Service
Mac, Windows 11
