2007-10-10
04:25 AM
2023-05-23
05:05 PM
Rubia Torres
2007-10-10 06:45 PM
Thomas wrote:Yup, Niel's stuff is probably the best out there (I probably should have mentioned that myself) but I still found it impossible to adjust them precisely for particular orders. Part of the problem of course is that there are no hard and fast rules about the proportions. Beyond the basic five classical orders (of which there are many variations in Greek and Roman examples) there variations by Vitruvius, Scomozzi, Bramante, in the renaissance to Robert Adam, Robert Orr and others today.
The D3 smart parts Trim library contains some customizable columns and caps that look quite good, with entasis and all. (but I'm no expert).
http://www.ddgi.com/object_shop/d3sp-shop01-libs-tr.html
2007-10-10 09:52 PM
2007-10-10 10:38 PM
Erich wrote:The usual management issues apply. If you don't have the library all you get is the dot.
Mathew & Thomas,
While I know about the D3 columns, I had not seen one closely enough to tell how good they are, Many things look quite nice when seen small but can prove otherwise. It sounds as though they are reasonably correct which is good.
Since the D3 parts are not part of AC are there file management issues beyond general library management? If one does not have the D3 parts will they show up in a file or do you just get a dot?
2007-10-11 12:26 AM
Matthew wrote:And not the least important: Palladio!
2007-10-11 09:19 AM
Thomas wrote:Well, yeah, you've got me there. And then there's that Michelangelo guy...but then he didn't write the books (or any?).Matthew wrote:And not the least important: Palladio!
http://en.wikipedia.org/wiki/Andrea_Palladio
2007-12-17 01:29 PM
Erich wrote:In all libraries is "Column Architectural". Column contains different order. "Tuscan", "Doric", "Ionic" user accessible. "Corinthian" and "Composite" hidden from the user.
Also, in AC 11 in the US library at least, there is only a Doric option.
values "ctyp" `Tuscan`,`Doric`,`Ionic` !!!values "ctyp" `Tuscan`,`Doric`,`Ionic`,`Corinthian`,`Composite`Rewrite them as follows:
!!!values "ctyp" `Tuscan`,`Doric`,`Ionic` values "ctyp" `Tuscan`,`Doric`,`Ionic`,`Corinthian`,`Composite`
2007-12-18 03:37 AM
