To launch a rendering with ArchiCAD 19, I clicked ctrl+9, instead with ArchiCAD 22?
To launch a rendering with ArchiCAD 19, I clicked ctrl+9, instead with ArchiCAD 22? Thank you
13 Replies 13
David Maudlin
Barry wrote:
So in version 19, when you go to the Work Environment, what one is it using?
If it its one that has been created specially for you, you can export it and then import it into your new version of Archicad.
But be aware that a WE from an older AC version will not have any commands for new features added in the newer AC version.
David Maudlin / Architect
www.davidmaudlin.com
Digital Architecture
I didn't do any customization in Archicad 19, I installed it and the shortcuts I saw written next to the buttons. I didn't understand what I need to see in Archicad 19 in Working Environment, so I'll put an image on you. Thank you
In Archicad 19 I did not do any customization, I saw that next to the buttons there was a ctrl... written and used that. In the image I allege the Working Environment of Archicad19.
From that image you have the Standard Profile 19 set as default - which is fine.
If the shortcuts are not the same in 22 (and you are using Standard Profile 22) as they were in 19, then unfortunately you will have to create your own shortcuts.
You can export them from 19, but as David pointed out and I forgot to mention, yo will end up missing any new commands that have been added to 22.
So you are better of customising the Standard Profile 22 (and ideally saving it as a new profile so you can always switch back to standard if you need to).
I do not have your language version of Archicad (ITA ?).
So I have no way of knowing if the shortcuts may have changed between versions.
