Trace Reference Palette?
Dave Jochum
This is peculiar. My TR palette has always sat nested with other palettes on-screen. It's disappeared and I can't get it back. I can toggle in on and off through the Window-Palettes-Trace & Reference menu item, but it doesn't show. I have full control of TR by right-clicking a window, but no floating palette. Work Environment changes don't help.
Dave Jochum
J o c h u m A R C H I T E C T S http://www.jochumarchitects.com
MBP 16" (M1 Max) 64 GB•OS 15.3•AC 28 Silicon (latest build)
9 REPLIES 9
Did you accidentally move it off screen and now it is not reachable?
One way to solve this in the PC world is to reset the screen resolution
to a much higher resolution. If your palette was off screen, it
now is in range and you can move it back into the center, then reset
screen resolution to your fav.
HTH
Snap
PS Of course it also resides on the Standard Toolbar.
Dave Jochum
HTH
Snap
It did occur to me that it could be off screen, though it seems to be physically impossible to move a palette completely off. I use two monitors, both set to max. resolution, so can't try your test. Anybody have other ideas?
Dave Jochum
This is a scary move, so as last resort;
(I've never had to do it myself).
File>New(and hold down the Alt key
for: New and Reset All
Try a different Work Environment.
Dave Jochum
Thanks, Matthew, but as I indicated in my initial post, that has no effect. I'm still stymied.
Dave Jochum
Link
New & Reset Alls are not that scary. AFAIK all they do these days is create a new file using the GS template and resets to the default (company) work environment. Have you thought about unplugging the second monitor and lowering & raising the resolution and changing work environment? That might jiggle it back on the screen.
Are you sure it's not just collapsed or hiding behind another palette? It may be worth systematically closing all other palettes to make sure.
Failing all of that you may have to run an ArchiCAD Cleaner or reinstall.
Link.
Dave Jochum
Thanks, Link. I found that bugger. I had moved all the palettes and windows around looking for it, but closed the palettes down as you suggested. Turns out it wasn't behind another palette, but cleaning up my two monitors allowed me to notice about 6 grey pixels in one of my monitor's corners. It was the corner of the TR title bar--virtually invisible.
Thanks to all.
Dave Jochum
Link
Great!
Yes it's happened to the best of us. As a trainer, I've come across it more times than I care to remember. Often the answer can summarized in two words:
Look harder!
Surprised the different work environment profile didn't work. Maybe we should have said try a different Palette Scheme, as it may not have changed even between different profiles.
Anyway, glad you found it.
Link.
Dave Jochum
Some glitch caused the problem, as I never move my palettes and it is physically impossible (OK, digitally impossible) to move a palette that far off screen. There is a limit to how far they will slide and this was way beyond the limit. There was barely more than a dot showing. Very peculiar.
Dave Jochum
