Trace Reference slows down performance
I've noticed strange behavior of AC12 when using trace reference. Even in not so complicated projects sometimes turning reference on will slow down redraw significantly (takes long minutes to redraw when zooming in/out) but sometimes allows to navigate smoothly. Can't figure out the reason of this. Memory seems to be enough and turned to max.
Please advise. Thanks
4 REPLIES 4
It may have to do with using a viewpoint vs a view as your trace reference.
See this wiki article on ways to speed up performance:
http://www.archicadwiki.com/2D%20Speed%20In%20ArchiCAD%2012
Thanks Karl, this helped a lot.
I was referencing to a worksheet before thru the view map and now I'm calling it out from project map and it works a lil faster. Hope it was the only reason...
Glad it helped.
Djordje
it is the only reason.
You can also check the 2D OpenGL accelleration - depending on the type of the video card, it might be better to switch it off.
In general, use only the Project Map for Trace. The settings will be as in the current view anyway.
Djordje
ArchiCAD since 4.55 ... 1995
HP Omen
