Trace not aligning
- Mark as New
- Bookmark
- Subscribe
- Mute
- Subscribe to RSS Feed
- Permalink
‎2009-08-17 10:36 PM
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
‎2009-08-17 11:20 PM
Mac OS 12.2.1
ArchiCAD 25 Build 6005
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
‎2009-08-17 11:47 PM
Architect, Consultant
Mac OSX 10.11.1
AC5-18
Onuma System
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
‎2009-08-18 02:15 AM
I have often found similar situations when comparing sections. Although your plan shows the sections to be similar in horizontal - your trace may be picking up the location based on a previous trace.
As Chris said you can simply drag a reference to make it align as you wish.
Right click > Trace > Drag Trace - in my experience once I have aligned similar sections they remain aligned. (At least until I drag a trace to another reference)
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
‎2009-08-18 12:59 PM
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
‎2009-08-19 02:11 PM
Chris wrote:I know I can drag them to align, but I shouldn't have to. Trace knows where things are in relation to each other and should automatically align itself.
You can drag the reference to align it. Check your trace reference options.
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
‎2009-08-19 02:12 PM
Erika wrote:Yes, the issue is not with the vertical alignment, but with the horizontal alignment. Everything is fine with the story settings.
The section you show is through the garage which from the stairs in plan is several feet lower/higher than the rest of the house so the sections are aligning correctly. Turn the story levels on to check.
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
‎2009-08-19 02:23 PM
owen wrote:Yes, the sections are both in the same direction.
Are these sections looking in the same direction? Just thinking they might be flipped around the origin if not .. (can't see where the origin is in the image)
Most of the time, trace aligns itself. For example, I have a section cut through a certain part of a building. Let's say I go to the elevation of the building looking the same way as the section, and I turn the section on in trace reference in the elevation, it shows exactly where it should. This is what should happen. But, as you can see in this example, it is not. There is a button in the trace reference palate that says "Reset to default position". Pushing this button should put it to where it's supposed to be, but it does not.
I've found that sometimes trace shows up in the right spot, sometimes they do not. Just wondered if there was a "magic button" to fix all my problems...
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
‎2009-08-19 02:40 PM
