‎2006-05-30 08:04 AM
Matthew wrote:I'm puzzling over this myself. I thought the point of the tracker was to eliminate the coordinate box. I'm for anything that reduces the stuff on the screen to a minimum. I've found shortcuts for most of the other things on the coordinate box, but it seems the only way to switch from absolute to relative coordinates in the tracker is to go deep into Work Environment menus and uncheck a box. That's a deal killer for me. So I've kept the coordinate box, but then why have the tracker? Is there a shortcut I'm missing here?
.... But I still haven't given up the control and coordinates palettes, and I not sure that I will any time soon. They still do things that I haven't found substitutes for in the guidelines and tracker.
‎2006-06-01 12:42 AM
I had some funny issues when using surveyor units and the tracker was incorrectly entering the angles. I had to physically click in the coordinates box to get the angles entered correctly. I need to do some mores testing to see if it is a persistent problem...Not sure if it's the same thing, but there's a problem in that if you hit A to enter the Angle setting, then want to hit D for distance, you will start entering degrees as part of the angle instead. I guess the trick is to use R to get to Distance, but it's a bit wishy-washy.
‎2006-08-05 09:09 AM
‎2006-08-06 11:55 AM
David wrote:Well put, totally agree although my coordinate box never left the screen.
Well, I tried, god knows I tried, but I've finally decided to reinstate the coordinate box and relegate the tracker to my rarely needed toolbar of cheap tricks. It just wasn't working out.
Now... about those guidelines. At first I thought it was cool that the ArchiCAD screen looked like the guy from "A Beautiful Mind" working out a mathematics problem. But, the thrill is gone. I want you back, control box. Can you ever forgive me?
‎2006-08-07 12:31 AM
David wrote:
cheap tricks.
Rod wrote:amen. all flash and no bang. let's hope that graphisoft now develop the 'pro' tracker - effectively the co-ordinate box on wheels - with relative/absolute toggles and containing
New toys for new users!!
David wrote:i think guide lines are about the only useful new addition to the archicad on-screen experience in 10 - and only then occasionally! i have them set to show only after 100 seconds (the max value) but have a single key shortcut to activate them when
‎2006-08-07 03:44 PM
~/archiben wrote:On: Guides, tracker (on-demand, + unless it's bugging me), Coordinate box, Control box, surface selection highlight.
‎2006-08-07 04:22 PM
‎2006-08-07 05:49 PM
‎2006-08-07 08:19 PM
‎2006-08-07 08:26 PM
‎2006-08-07 09:13 PM
