Transfer multi story building into new Archicad file
- Mark as New
- Bookmark
- Subscribe
- Mute
- Subscribe to RSS Feed
- Permalink
‎2022-10-26 07:24 AM
Hi all. I have been working on a multi level building and now want to copy into a new file.
I use the thick marquee to copy all stories, however only 1 story is transferred?
Appreciate any help!
Thanks
Solved! Go to Solution.
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
‎2022-10-26 07:51 AM
....all good, just created a mod file and worked.
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
‎2022-10-26 07:46 AM
There is an option under the file menu to ‘Merge’. You can import an entire model or all of the layouts. I don’t have access to Archicad at the moment to say exactly where it is but it’s definitely in the File menu.
macOS Sequoia (15.1.1)
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
‎2022-10-26 08:13 AM
Cool. I assume you know that you won’t be able to modify the model without opening it in the original file.
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
‎2022-10-26 08:19 AM
I haven't hot linked it so its fully editable. I simply merged the mod file.
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
‎2022-10-26 09:23 AM
Or, if you did hotlink it, you can break the hotlink.
