2012-04-23
04:07 PM
2023-05-23
04:36 PM
Rubia Torres
2012-04-23 04:22 PM
2012-04-23 04:53 PM
2012-04-23 05:04 PM
2012-04-23 06:19 PM
2012-04-23 06:57 PM
2012-04-23 08:26 PM
Enrico wrote:Not possible. All ArchiCAD elements are recognized by the tool that inserted them, regardless of their virtual function. There is no mechanism for converting one thing into another, other than (1) anything can be converted to an object [by saving], (2) a multiplane roof can be converted to single plan roofs, and (3) with the mesh-to-roof add-on, a mesh can be converted into a collection of single plane roofs that follow the mesh surface.
I don't need a column to be a beam. I'd like the option to transform an object into either a beam or a column. I'd like to be able to insert an object-beam from the Archicad library > structures > steel beams and have Archicad recognize it as a beam instead as an object.
2012-04-23 11:05 PM
Enrico wrote:This could be done via the API, but I assume this isn't something you would do so often that it would be worthwhile.
2012-04-24 07:52 PM
Karl wrote:Not really a conversion but the magic wand often serves a similar purpose.
Maybe some other conversions that I cannot think of...
2012-04-24 09:47 PM
