‎2004-03-24
04:49 PM
‎2023-05-26
03:28 PM
Rubia Torres
‎2004-03-24 05:11 PM
Tom wrote:This setting is here :
How do I turn off the transparency.
‎2004-03-24 05:15 PM
Tom wrote:This has always been a bit quirky. In the past this was a global setting controlled by Image > 3D Window Setting: Transparency in Shading. I have just done some quick testing and it seems that it now depends on the state of this setting at the time the section is first generated (for model views anyway).
Right now on my elevations, I can see through the windows. I am using the Open Gl engine. How do I turn off the transparency.
‎2004-03-24 05:35 PM
Matthew wrote:Oops, I hadn't read correctly the question !
BTW: OpenGL has nothing to do with transparency in section.
Matthew wrote:As Matthew said, the transparency in section / elevation is controlled by the 3D window setting... and it will be save when defining a view in a view set.
I have just tested this with drawing views and they retain the transparency status of the original model view and continue to retain it when regenerated.
Note that this testing has all been done in the same session of ArchiCAD. I am assuming (hoping?) that the results will be no different after closing & reopening the file (or quitting and restarting AC).
‎2004-03-26 10:01 AM
‎2004-03-26 10:10 AM
ittai wrote:Can you explain how to do this ? What is the "match properties" tools ?
I have fond, that it is possible to create a new elevation with the transparency set to "off" and then use the "match properties" tool on older sections/elevations that have transparency "on", thus changing them to "off"
‎2004-03-26 10:21 AM
‎2004-03-26 10:36 AM
ittai wrote:It probably depends on the way you create your elevations : save as PMK directly, publish as PMK from a quickview or link them in Plotmaker.
It seams that modifying one elevation in the manner described in my previous e mail will change the setting of all elevations in drawing at once !
‎2004-03-26 10:41 AM
