Transparent window frame
There are 3 views about my transparent window frame
It's a composite wall with only original archicad materials and column
It's allways the same window from the archicad library
These transparent window frames are on AC22 and AC21
I have to work on AC22
I have tested to check graphic overrides, model view, layer priority, surface and material priority without success
Christophe - FRANCE
Formateur Archicad indépendant à NANTES, PARIS
Archicad 15 to 29
1 Reply 1
I have found the reason.
My first material was an empty material which turned on the frame of my windows.
I have deleted this first material and shift my wall reference about the same thickness.
Christophe - FRANCE
Archicad 15 to 29
