We are experiencing a temporary disruption to our licensing service. Our team is working to resolve the issue as quickly as possible. We appreciate your patience and support.
Tread line for stair is vanished
Dear Friends,
I am having an issue with my stair. All lines at visible parts have removed(See Fig-1). Their outline can be seen after selection (See Fig-2). I already checked the possible parameters. For example.
1. Pen Set & Pen
2. Different Model View
3.Graphic override
It's almost 6 hours I am stuck with this issue.
Here is the pln file for the stair. It will be a great help if you can take the time to check my pln file attached here.
https://drive.google.com/drive/folders/1HoPemWealilZupHBdaPEd_ktOwr1ReUG?usp=sharing
Guru
Check the stairs floor plan overhead setting.
I tried my best but I can't fix it.
The combination of the below two settings can cause Stair Treads on the visible portion of a Stair to not be displayed:
