Triangle shape gutter
I am creating a triangle section gutter with 3% slope. I already made the solid morph, but I wonder how can I hollow to a wall thickness of 2mm.
DGSketcher
Legend
Did you consider using a beam with a complex profile?
Erwin Edel
Or Detailed Extruded Shell?
I like using those for gutter detailing.
www.leloup.nl
ArchiCAD 9-26NED FULL
Windows 10 Pro
Adobe Design Premium CS5
The trick with using a morph to do this would be to first create a polygon morph in section for the profile shape you need.
Then extrude or tube it.
Rather than trying to create a solid gutter and then hollowing it out.
However you will probably find it easier to use a complex profile as suggested.
Basically it is the same as it is a profile you extrude.
But being a complex profile, you can tweak the shape easily if you need to.
