ngoldie
Trim elements to roof shell
I have a wall that had been trimmed to a roof, I then raised then roof but the wall did not follow up with the height. I then tried the "clear all connections" option for the wall and it doesn't work, I tried it on other walls and it isn't working on them either?
Thanks
Naomi
Archicad 20
MacBook Pro - laptop
3 Replies 3
David Maudlin
Naomi:
Check the height of the Wall. The Trim command will cut a Wall, but will not extend its height.
David
David Maudlin / Architect
www.davidmaudlin.com
Digital Architecture
DGSketcher
Legend
Apart from trim to roof and Solid Element Operations there is also a crop option which seems to be being buried by GS. If your wall is not automatically adjusting to follow the trimming element, subject to wall height limits, then it may have been cropped. "Clear all connections" doesn't work with cropping. You need to look through the wall info bar at the top of the screen where you should find reference to "Wall cropped" highlighted and an option to undo the cropping. Note this undo option doesn't appear in the settings window.
ngoldie
That was it! The wall was cropped - under Roof Extras.
Thanks!
Archicad 20
