2008-10-28 01:43 PM - last edited on 2023-05-23 03:07 PM by Rubia Torres
2008-10-28 02:26 PM
2008-10-28 05:33 PM
2008-10-28 07:36 PM
Dwight wrote:This is an advantage of Trim to Roof over Solid Element Operations. Trimmed elements will stay trimmed even if you remove the trimming ones.
I overlap the roofs to do the trim function and then move them back.
2008-10-29 01:17 PM
Djordje wrote:To add to this one: sometimes the roof edges at the valley are not vertical. You can select the common Roof edge for each roof and make sure its angle is set to Vertical.
Select one roof plane, with the roof tool active. CRTL click the edge of the valley on the other roof plane. Repeat with the other roof plane.
See old ArchiGuide on roofs - all the basic techniques explained.
http://www.graphisoft.com/archiguide_archive/ArchiGuide_Online_6o/issue15/roofs.html
Still valid ... some stuff is obsolete, but the basic principles are there.
2008-10-29 10:04 PM
2008-10-30 12:26 PM
2008-10-30 04:04 PM
2008-10-30 07:00 PM
2008-10-30 07:08 PM
