‎2004-02-04
02:01 AM
‎2023-05-23
03:44 PM
Rubia Torres
‎2004-02-04 02:27 AM
‎2004-02-04 02:47 AM
‎2004-02-04 03:56 AM
Tom wrote:The walls should be higher than the roof; that is, in 3D, you should see the walls piercing the roof. The roof polygon should cover the walls completely.
When I select roof, wall, either or both, the camera tool and in the edit menu, "trim to roof are both greyed out".
‎2004-02-04 04:14 AM
‎2004-02-04 03:25 PM
‎2004-02-05 01:07 PM
Tom wrote:Elevations and sections are not so good for editing, except if you move around and align doors and windows. The roof trimming works in the plan and 3D window. Make it a habit to work in the 3D window as much as possible, and then some; shame not to squeeze all that OpenGL horsepower out of your expensive video system!
Thanks for the 3D tip. I did not realize this command only worked in 3D. I assumed it would work in the elevation view as well.
‎2004-02-05 02:19 PM
