Trimming A Web Beam Curved object
Is it possible to trim a Web Beam Curved (curved Truss) to a wall or slab?
1 REPLY 1
You can use Solid Element Operations (SEO) to achieve that.
But consider that the 2D of the object will not update based on the SEO.
I think using the Objective Add-On you can do cuts and trims like that and the 2D WILL update.
