2022-08-05 11:02 PM
When I trim the main gable to this shed dormer to remove it from the interior, it also deletes the portion underneath the dormer overhang, is causing a hole in the wall and a portion to extend past where I want it. Whats the easiest way to fix this?
2022-08-05 11:45 PM
Have you tried solid element operations? This doesn’t show correctly on plan though. There is a way to make it work but I can’t remember the best way without tinkering with it.
2022-08-06 12:00 AM
@ScoutTownsend You may want to consider using the crop to single plane roof function...
2022-08-06 12:12 AM
That’s the kiddie.
2022-08-06 10:15 AM - edited 2022-08-06 10:16 AM
use crop to roof, always. everything else results in issues.
