2006-08-07 01:53 AM - last edited on 2023-05-23 05:14 PM by Rubia Torres
2006-08-07 02:04 AM
2006-08-07 02:16 AM
2006-08-07 02:28 AM
2006-08-07 02:49 AM
2006-08-07 02:53 AM
2006-08-07 03:07 AM
2006-08-07 03:27 AM
2006-08-07 03:28 AM
Renata wrote:I can't recall seeing this, nor can I guess what would cause it under normal circumstances. Perhaps a "New & Reset" under the File Menu would help (hold down the option key). Perhaps you need to reinstall ArchiCAD. (I assume you have tried restarting ArchiCAD and restarting the computer.)
My geometry method is on the free rectangle. But I can't change it or the other two settings in my info box. They are frozen, white.
I also cannot change my origin point setting. When I click on it, it turns grey, but when I go to the floor plan, it goes white and the origin point appears wherever I click.It sounds like the origin point button is doing just what it is supposed to do. When you click it you are say "I want to move the origin to the next place I click." (Note: If you double click it will return to the absolute "project origin".)
I recognize I probably hit a set of keystrokes -- how do I get out of this mess?Beyond what I have said, I am not sure what else it could be.
I should have thanked you for your feedback before! I sincerely appreciate your suggestions and your help!!!!Your welcome.
