2004-06-27 11:19 PM
2004-06-29 04:06 AM
2004-06-29 05:23 AM
2004-06-29 12:25 PM
Erika wrote:Take a look at FrameWright - it is perfect for constructing and editing complex assemblies with timber and steel. Have a look at
Using trussmaker, the wood member and rectangular steel options do not seem to offer the option of adding steel connector plates, or am I just not seeing where to do this?
2004-06-29 06:00 PM
Ralph wrote:Ralph,
Take a look at FrameWright - it is perfect for constructing and editing complex assemblies with timber and steel. Have a look athttp://www.encina.co.uk/framewright.htmlThere is a time-limited demo available, so you can try it out first.
2004-06-29 07:43 PM
Erika wrote:We don't believe it is possible to express all the ways companies put steel and timber together in an object. You only end up with a huge, incomprehensible list of options and settings which still can't be fine-tuned to specific installations. FrameWright is designed to allow you to construct complex assemblies from many simpler parts rather than employing individual, massive objects. This means:
I looked at the pdf, but I didn't see steel conector plates on the wood framing.
Erika wrote:It is quite normal for your serial number to be encoded into the license number of an add-on. And as far as I know, the information can't be put to any negative use. Encina Ltd is also a UK ArchiCAD dealer, so we hold this kind of information in the normal course of business. Does that answer your concerns?
It looks like a very nice product, but I didn't download the demo because I am uncomfortable with your wanting my archicad dongle number as part of the deal for a free time-limited demo.
2004-06-29 07:52 PM
Ralph wrote:No. I've never been asked for that number by anyone other than graphisoft and I would prefer to keep it that way.
2004-06-29 10:02 PM
Ralph wrote:You send the serial number away when you serialise a Cigraph add-on too - perhaps you weren't aware of that? That is how the product is restricted to your dongle. The API allows an add-on to extract your serial number without asking (even GDL can do this), but we prefer to explicitly let you know what is happening. How would you like the demo and licensing to work?
It is quite normal for your serial number to be encoded into the license number of an add-on. And as far as I know, the information can't be put to any negative use. Encina Ltd is also a UK ArchiCAD dealer, so we hold this kind of information in the normal course of business. Does that answer your concerns?Erika wrote:
2004-06-29 10:31 PM
Out of interest, does anyone else know of a reason why the dongle number should be kept private?
2004-06-29 10:57 PM
Erika wrote:Your number is only wanted for one thing: calculating a registration code to send back to you for the add-on. Once the code is calculated and issued, the serial number is of no further use. No one is trying to be underhanded about this. The purpose is simply to ensure only the purchaser of the software (the dongle owner) can use it.
I am unaware that other APIs encrypted code to relay my archicad dongle number. If true, that is not exactly putting a smile on my face. If it is standard that API people need the AC dongle number, why aren't they up front about it?
I'm not in the habit of giving out information just because someone would like it.
