Learn more
edwardlouie
Trying to Make Railing Horizontal
I'm trying to make horizontal railings for a deck however they keep making themselves sloped at the ends. I can't seem to find the setting to get the railings to not do that. Can someone suggest a solution? I'm new to Archicad but so far the good has outweighed the annoying things about Archicad. Thanks.
Screen Shot 2022-02-25 at 9.38.49 PM.jpgScreen Shot 2022-02-25 at 9.39.18 PM.jpg
1 Solution
Dontknow
You can do this in your elavation view or in your 3D view along the Z-axis.
railing
Architectural construction designer, draftsman, modeller
ArchiCAD 25.
Go to post
4 Replies 4
The railing will follow the blue reference kine.
On end is at the top of the slab and the other end as at the bottom.
You should be able to select the node at the end of the line and drag it up.
Dontknow
railing
ArchiCAD 25.
Djordje
the main issue with any software is that it does what you tell it to do, not what you want it to do
Djordje
ArchiCAD since 4.55 ... 1995
HP Omen
edwardlouie
Thank you Dontknow and Barry. I was able to find the move node tool in the pet pallet and make the adjustment in the elevation view. Thank you.
