2017-07-14
06:30 PM
2023-05-23
04:14 PM
Rubia Torres
2017-07-15 07:02 AM
2017-07-15 01:22 PM
2017-07-15 04:25 PM
arg617 wrote:Rationale? Having seen US Default Pen sets over the past 20 years, as well a number of other systems, I can tell you that the defaults have changed frequently in most respects, EXCEPT for the 1st row, and Pen 91. The logic of the assignments in the first row escapes me, but it seems that pens 1-3 are used in the OOTB wall definitions. The "US ArchiCAD 18 Default" set has pretty complete descriptions for each pen, but nothing to indicate why they were organized this way, and I've never found any documentation. There is no "perfect" pen set, because even if you found that the US defaults showed US library objects consistently and logically, you will be using objects from somewhere else, and then the pens are all wrong. (e.g. Cadimage objects look horrible in the US defaults.) I've come across sets that were organized beautifully, but still had no relation to any standard GS content. So, if you are already using Jared's template, that's as good as any, and probably better than most.
Is there no actual documentation of the rationale behind US pens? I might have to stick with the Shoegnome pens if there isn't, but Graphisoft must have this documented somewhere, no?
2017-07-15 08:11 PM
arg617 wrote:As the article you linked to notes, pens 1-20 are the library part pens. And, the US still expects pen 91 to be white. If you leave those alone, your library parts should come out without requiring major changes. (Disclaimer: I haven't checked recent US libraries to verify that this is still the case. Link had a post somewhere that noted some library parts using a few random pens above 20.)
I've been working with a template that modifies the pens and have grown frustrated at having to adjust pens every time I use a new object.
