Unable to edit the slab thickness,box grayed out...
Slab default settings dialogue box in the geometry and positioning tab.
I'm not able to change the slab thickness.It is already fixed at 30cm and grayed out.
I had no drawing problems before,if so I'll solve it from the help page.
Thanks for your help.
Using AC 10.win xp pro sp3.
2 Replies 2
The slab is set to a COMPOSITE cut fill. This is always static. Change to a standard cut fill and all will be good.
Richard
AC26 (since AC6.0), Win10
perfect,and thanks.
