Undo the last polyline point
Paopao
Hi guys,
how do I undo the last polyline point(s) in Archicad? Sometimes I draw a polyline with many points and I realise that I want to keep it up to (let's say) three points "ago": is there a way to undo only the last point(s) without having to delete the whole polyline and draw a new one again?
thanks
PP
AC26 EDU • WIN 10 • Intel Core i7 2.8 GHz• 32G RAM• NVidia GForce GTX 1080
Use the Backspace key to undo the points you have been placing.
Clarification - this is while you are drawing the polyline.
As Barry said if you are still drawing the polyline.
If you have already completed it, you can stretch the end point of a polyline using the pet palette back to the previous point to delete a segment. If you want to go back three points you have to do it 3 times.
OR just trim the polyline to the point you want (CMD+click on Mac)
Paopao
I ment exactly while drawing the polyline. So I will use the backspace!
Thanks a lot guys!
