Undocumented Improvements in AC15
Link
Here is the beginning of a list of 'minor' fixes in AC15 that I was personally involved in. I hope that others may be able to add other undocumented improvements to it:
1. Mirroring text now mirrors the anchor point.
2. The Help menu search function is no longer case sensitive.
3. Fill Area Text's are transferable via the eyedropper/syringe.
4. Project North now accepts up to 4 decimals (when set in working units).
5. Right click on Layouts and Masters to edit their settings.
6. Module Save Options have a new display setting.
Link.
56 REPLIES 56
You still learn new things everyday!
But then this one is really AC15 (I hope): true projection of roofs including Custom Edge Settings.
Radial Distorted Fill is older than 15, but the button is now always visible. In 14 (And 13 I presume), the option only showed up if you exploded a circular wall that met all the criteria. Which as everyone knows only happens a few times per project.
Jared Banks, AIA
Shoegnome Architects
Archicad Blog: www.shoegnome.com
Archicad Template: www.shoegnome.com/template/
Archicad Work Environment: www.shoegnome.com/work-environment/
Archicad Tutorial Videos: www.youtube.com/shoegnome
Yes, I will give you that one!
It's a shame with that option you now loose the ability to select a symbolic view of any rooflights placed. They are all projected as well.
On a related note - Where is the overhead linetype and pen for rooflights found now? I'm just seeing a solid line the same as the uncut portion.
Edit - Found it! For some reason you have to untick both 'Enable Object's Linetypes' & 'Enable Objects Pens' in the floorplan and section tab in the object settings. Seems counter-intuitive to me.
Is that undocumented?
Several New Feature videos on YouTube talk about it.
The Special Menu has been divided into two parts: 59 GDL Developer and 60 Special Menu. There is a new command 'Run Parameter Script of all Placed objects' and I can really use that!
The help has been expanded: this part is about the Element Listing Parameters in the Interactive Schedule
vfrontiers
vfrontiers wrote:
And for the love of all things good... please keep the TOOLBOX where I put it on a MAC! Every time I open ArchiCAD... it's bad enough that I have to move it back in place... but the darn thing resizes to the full height of the screen but is placed down 40 or 50 pxls so I have to drag it UP, resize it smaller, drag it down into place then drag it to fit the space I've left for it...
.... A little CHEESE to go with that WHINE!....
1. Crow tastes good!
2. It looks as thought GS DID fix this in AC15!
Duane
Visual Frontiers
AC25 :|: AC26 :|: AC27
:|: Enscape3.4:|:TwinMotion
vfrontiers
Laura wrote:
Master wrote:
another one, the Quick Layers toolbar can now be docked!
It may dock, but it's still not saved as one of the Palette settings in the Work Environment.
I find some STRANGITY here too... I ALWAYS want Quick Layers open and visible (and in the same place I leave it)...
Ea time I open up AC... it disappears..
But... If I open up a floating palette (like COMPLEX PROFILES) and edit and store... Voila, the quick layers palette has re-appeared in the center of my screen..
Duane
Visual Frontiers
fuzzytnth3
I get round this by making a toolbar for the Quick Layer and also TW commands and save that with my Work Environment. It then stays available at all times
Using AC25 5005 UKI FULL
vfrontiers
I just TOOLBAR'd the quick layers a couple of days ago... Doesn't look as nice, but the buttons are there...
I may do the same for TOOLBOX as my previous post about how it nows stays put was premature! Seems if I have it ONE tool wide and pretty much the height of the screen, it does stay in place... but tucked in 3 tools wide and short, it continues to plant in some random place each time I open a file!
Duane
Visual Frontiers
