2004-10-20
06:54 PM
2023-05-26
12:54 PM
Rubia Torres
2004-10-20 06:55 PM
2004-10-21 07:53 AM
2004-10-21 08:00 AM
2004-10-21 12:52 PM
Dwight wrote:Now that we have to deal with them, they are very important.
Are intersection priorities important to many other users?
2004-10-21 04:24 PM
Are intersection priorities important to many other users?Yes. Especially for remodel jobs and you use a wall to be removed layer. Without intersection priorities the hidden walls "clip" existing or new walls that are showing in the plan.
2004-10-21 05:01 PM
Are intersection priorities important to many other users?They are VERY useful! To add to Matthew's post, some other important things to note are:
2004-10-21 09:25 PM
Link wrote:Ah, Link my man! That deserves a tip-of-the-month! If this feature is documented, I never noticed it ... but I've wondered why sometimes I couldn't get the "inherit attributes of operator" to work and other times it did. Thank you!
The consequence of these intersection priority numbers are important in Solid Element Operations. Lets say for example you use a white beam (or any other 3D non-wall element) to subtract a recess out of a brick wall. To make it a white recess, you would set the SEO subtraction so that the 'New Surfaces of Target will: Inherit Attributes of Operator'. However, if the layer of the beam has the same intersection priority number as the layer of the wall, the recess will still appear as brick. You will need to change the intersection priority number of one of them (say the beam) to get the recess to show up white.
2004-10-21 09:49 PM
Dwight wrote:Really important. Without them, I'd have to use the patch tool quite a bit to get my drawings to look right. (If I used composites more, I'd still have to use the patch tool, but that's another story....)
2004-10-22 04:54 PM
Ah, Link my man! That deserves a tip-of-the-month! If this feature is documented, I never noticed it ... but I've wondered why sometimes I couldn't get the "inherit attributes of operator" to work and other times it did. Thank you!Thanks Karl. It seemed like a little find, in the grand scheme of things! Sometimes I submit posts that I find extremely valuable and no one blinks an eyelid. Then times like this when I flop in front of my laptop, before my morning coffee, and tap out a sleepy wake up post, it turns out to be pretty useful. Ahhhh - this is the beautiful thing about ArchiCAD-Talk. You never know what your going to get!
