‎2006-11-09
06:19 PM
‎2023-05-25
06:16 PM
Rubia Torres
‎2006-11-09 06:25 PM
‎2006-11-09 08:45 PM
Tom wrote:That shouldn't happen if you have saved Layer Combinations and have them assigned to the views. Have you done this?
...the view gets rebuilt, but with the layer state that is open on the floor plan at the time the command is executed.
‎2006-11-09 09:09 PM
‎2006-11-10 05:31 PM
Tom wrote:I does for me. Sometimes I swear, when all I needed was one (1) view to update in a layout. Have you tried this (and note, if you have your layer combos set up and saved wiht the views, they should all show the layers originally assigned)
If I update layouts through the drawing manager, will AC update views?
‎2006-11-11 01:58 AM
s2art wrote:it should: because you're not rebuildingTom wrote:That shouldn't happen if you have saved Layer Combinations and have them assigned to the views. Have you done this?
‎2006-11-11 11:55 PM
‎2006-11-12 07:06 PM
‎2006-11-12 08:35 PM
Adalbert wrote:I've found them to be noticeably faster. I never thought I would leave my beloved PMKs behind, but this release changed my mind.
How fast or slow is 10 rebuilding views compared with 9 publishing PMKs.
I ask this because in 9 one could not work with linked views. It's much to slow for a decent job (30,000 sq ft 3 story mixed building with 50 30x42 packed drawigs)
‎2006-11-13 01:22 AM
