NandoMogollon wrote:
You can also create an Object for the buildings with GDL, but then it gets more complicated.
Thanks all for the great replies.
The accuracy is absolutely critical. We can fudge a urban landscape using Revit Conceptual massing tools, but what we need is for the urban landscape objects to be intelligent.
We need to pull alot of numbers, ie 5000 homes, plus schools, offices etc off the plans. Each home, office etc, needs to report a Gross Floor Area, a Plot Ratio, Urban Zone name and so on.
This all needs to be done fast. So when you place an office, you can just grab the top of it in CAD, drag it up to make it taller, pull the side to make it fatter and bingo, all the numbers appear in the schedule automatically (floor area, number of floors, height, zoning)...,place an automatic tag on it, then on to the the next building.
Incredibly, only the free Sketcup plugin called Modelur
http://www.modelur.com/
comes close, but it doesn't allow multiple urban zones, and it doesn't have a 2D printing ability (ie no tags for buildings and zones)
I noticed that there were issues with storey settings in a multiple building landscape as reported
here which sounds very similar to Revit, afterall these are programs for designing a building, not cities. The other limitation, out of interest in Revit, is there is a 5000ft limit to the width of the model.
We don't really mind, maybe, on getting involved in GDL if it solves the problem - but then equally, we could go down the VBA route in Autocad.
I couldn't get the
http://www.bimconcept.no/
link to work but I may be able to hunt down some posting by Urbanstrategies on forums somewhere to find out how they built their city models in ArchiCAD and if they were blocks or intelligent blocks they used.
Any more thoughts would be hugely welcome!
