Thanks for the feedback dv_chris and laszlo.
I already tried dv_chris suggestion to offset balusters with negative value, however it never quite gets it right.
Laszlo's pattern continuity does change the way the balusters behave but does not fix my problem.
I was able to come up with a solution / work around for my fence but not without some "fudging".
Rather than placing balusters only, I opted to do a solid panel with metal profile balusters in between. This eliminates any possible gaps. It did mean that my 3D representation will not be 100% correct from both sides but close enough for my needs.
Unfortunately AC21 does not allow to place balusters in same area as the panel. This is where using negative offsets allowed me to work around the problem.
I love the new tool but I do hope for some improvements that will make these non typical balustrade solutions a bit more practical. Will keep on playing with it to get some results. Picket fence coming up next. I imagine that should be a little more straightforward.
ArchiCAD 10 - 29 | Windows 11
Lucid Design Studio | Perth, Western Australia
