Arcadia
Vectorial Shadows in 3D Document
I can't find any settings to change the source of the shadows in the 3D document settings. Apparently shadows for 3D documents are seperate from the 3D window and changing the sun source in the 3D window doesn't seem to change the 3D doc at all. Anyone know how I can do this?
V12-V27, PC: Ryzen 9 3950X, 64g RAM, RTX5000, Win 11
13 Replies 13
I believe you have to redefine the 3D Document based on the current settings of the 3D Viewpoint.
Think of the 3D Document as a View, meaning it has stored 3D settings that are retained no matter what you do in the 3D Viewpoint until you redefine it.
Arcadia
Thanks thats got it sorted!
David Shorter
thats fine but you can't transfer the settings in the 3D document window to the 3D window so having created a 3D document you can never reproduce the settings in the 3D window.
Make redefining VERY difficult...
Archicad 4.1 to 28 Tech Preview. Apple Silicon
you can't build a line
Mac Studio
iPad Pro
iPhone
David, if you right click the 3D Document in the Project Map and choose Open Source View, isn't it what you are asking for?
David Shorter
Yes Laszlo, that is what I mean but it doesn't remember the sun settings which makes it unusable for a Sun Study ... its not consistent.
Mac Studio
iPad Pro
iPhone
David, I think the Sun Settings are stored and restored correctly, however, there seems to be a trick.
In the Model Display panel of the 3D Document Settings Dialog, you have to set the Vectorial Sun Shadow field to something other than OFF. Otherwise it is giving you the phenomenon you described.
David Shorter
Not sure I like "tricks" but I'll test it out.... I'll be back!!!
Mac Studio
iPad Pro
iPhone
David Shorter
Sorry Laszlo, trick doesn't work. Go to any 3D doc, open the source view and you will see, hopefully, what you expect to see in the 3D window as far as the shadows are concerned. Now open the 3D projection settings/more sun the date there will will always show the last saved settings NOT the ones currently displayed. A rebuild will have no effect so the 3D window and this will not match the More Sun settings.
On Mactel of course ......
I can send you some incredibly boring screenshots if you like
Mac Studio
iPad Pro
iPhone
OK, I see what you mean. I will report this to GS.
