2015-11-25 01:02 PM
2015-11-25 01:31 PM
2015-11-25 07:45 PM
Erwin wrote:It worked! Very ingenious manner to solve this problem. Thank you very much!
If you are on ArchiCAD17 and higher: create a building material with 999 priority. Make one or several shapes with slab tool, morph tool, whatever works best using this building material. Put it on a layer that is hidden. It should intersect with most of your model, depending on layer intersection group.
2015-11-25 08:54 PM
2015-11-25 10:16 PM
another Moderator
2015-11-25 10:36 PM
ejrolon wrote:Yes that option is only available on the plan view and not the 3D view. Not sure what the point of the marquee is in 3D view if it can only isolate it to one story.
Switch the 3D Marquee to Multi Story = bold dashed line
2015-11-25 10:43 PM
another Moderator
2015-11-25 10:56 PM
ejrolon wrote:
Then turn Cutting Planes on (Command+Y) and then drag a plane from the top.
2015-11-25 10:58 PM
another Moderator
2015-11-25 11:10 PM
