Verticle Datum question
I have the Vertical (datum) marker marking the window header hgts and clg. hghts. It always references the 0" elevation mark, is there anyway that I can change that so it references the 2nd or 3rd story? (I need it to be an automatic dimension, I know how to override)
I think it will confuse the builder to tell them the knee wall height is 23'-7" instead of 3'-2" from the 2nd story clg.
in real life application, they wont run a tape measure all the way from the 1st floor to the 2nd story knee wall etc.
4 REPLIES 4
Thomas Holm
Window tool settings dialog, Parameters pane, right side, choose your Anchor level from the menu
Actually I am needing to change the elevation marker text, to make it take a reference from a certain story. I am attaching a pic of what I am referring to.
Ideally I would like to be able to select what story I want that "datum" to reference its hgt. from, instead of always being from 0'-0"
OOPS, I apologize, my datum marker is a user object my guru made. Trying not to use him as a crutch but he has made so much I dont know what is common in ArchiCAD and what is his own homemade.
sorry
David Larrew
Lee,
I've thought about your dilemma, and I think I can make it work... I'll let you know.
David Larrew, AIA, GDLA, GSRC
a r c h i S O L U T I O N S
WIN7-10/ OSX 10.15.7
AC 5.1-25 USA
