ā2006-05-31 11:27 PM
ā2006-06-01 12:56 AM
ā2006-06-01 01:14 AM
ā2006-06-01 01:47 AM
I thought I could just open an old one in PlotMaker 9, copy and paste it into the new one. It comes in ok, but not at the same scaleHow are you doing this exactly? Are you copying the entire master, or just it's contents?
ā2006-06-01 01:55 AM
ā2006-06-01 06:13 AM
ā2006-06-01 12:47 PM
Steve wrote:Objects do work in Masters. All my title blocks are objects for AC10.
apparently objects don't work in master layouts. I just used an external drawing.
ā2006-06-01 12:50 PM
Steve wrote:Did you check to see if any of the missing elements are showing in a white pen? (and as such are invisible)
just content. Text, lines, fills, things in my title block. Some of which were objects which I can not get to work even if I open the old 9.pln in 10, and resave it again as a new 10 .gsm.
looks ok in plan view. not ok in layout. all layers on. Actualy, this one is a problem. Why would the object look different?
I tried to make a detail out of the object. It wont work either. However, if I open the detail, I can paste it into the detail right next to it and it will look just fine. Something is not right.
ā2006-06-01 01:56 PM
ā2006-06-01 02:00 PM
TomWaltz wrote:Steve:
