2023-10-06
04:51 PM
2023-10-08
06:35 AM
I have a problem with a wall line in section. When i insert door or window thicker wall cut line (part of the composite wall) is visible. It happens above slab and also under the slab where sunshade is inserted. I drawn red line just to show where the lower floor wall ends and the upper one begins.
2023-10-19 09:12 PM
Hi @ThiagoMar,
Have you reviewed the pen assigned between layers in the composites?
Best,
Community Expert | GRAPHISOFT SE
Did you get a helpful answer on the forum?
Give it back to the Community by marking it as an accepted solution!
