Visible thick wall cut line when i insert window or door.
ThiagoMar
I have a problem with a wall line in section. When i insert door or window thicker wall cut line (part of the composite wall) is visible. It happens above slab and also under the slab where sunshade is inserted. I drawn red line just to show where the lower floor wall ends and the upper one begins.
ā€ƒ
1 REPLY 1
Rubia Torres
Hi @ThiagoMar,
Have you reviewed the pen assigned between layers in the composites?
Best,
Rubia Torres
Community Expert | GRAPHISOFT SE
Need help refining your Archicad skills?
Check our Modeling knowledge base for the best workflow + tips&tricks!
