2012-07-1212:52 AM - last edited on 2023-05-2611:19 AM by Rubia Torres
2012-07-1212:52 AM
What settings or ... would be causing windows and doors to only appear in the 3D model and not the floor plan. I can place a door or window but do not see the symbol once placed only see it in elevation in the the model, suggestions, thank you????
Working in ArchiCAD V.12 on a MAC
See if you have the 2D display option for the windows/doors set to 'symbolic' - they will then ignore the Floor Plan Cut Plane (FPCP) and will likely appear. Alternatively, change the cut plane height...
AC 28 USA and earlier • macOS Sequoia 15.3, MacBook Pro M2 Max 12CPU/30GPU cores, 32GB One of the forum moderators
