WINDOWS+CIRCULAR WALL=?
Wall is always (?) split in two pieces. When you insert windows- the window inserted on the place of spliting (that cant be seen when inserting windows) is also split- and only a part of it is seen in 2D, 3D. Where is the catch ? Thanks.
Djordje
The catch is, as you correctly noted, that there is no such thing as a circular wall - you can have 359 degrees wall, not 360.
The trick is, to place the seam between the wndows. Rotate the halves accordingly.
Wishlist? I do think so.
Djordje
ArchiCAD since 4.55 ... 1995
HP Omen
