Walk mode not working as it should?
JohnJay
When I activate Walk mode and try to walk backwards the view rotates instead
Is anyone else experiencing this?
Could it have something to do with 4k monitor resolution/200% scaling?
AC27 | i7990x | RTX4070 | W10
12 REPLIES 12
It does show the correct down arrow when I press to move but the view veers off to the right instead
Just tried in AC25 and it works fine there so can't be anything to do with display or resolution as I originally thought so must either be a bug in 26 or some specific issue with my setup
Is it working OK for you/everyone else?
Erwin Edel
Walk mode has a sort of almost invisible box in the middle of the screen and if you have your mouse cursor below that box and click, the camera will move backwards, above forwards etc. If it isn't doing that, than something is wrong.
www.leloup.nl
ArchiCAD 9-29NED FULL
Adobe Design Premium CS5
