2023-02-03 02:16 PM - last edited on 2023-05-09 02:19 PM by Rubia Torres
The priority are good ,
but the lines of wall core continue to the outside of the other wall.
Solved! Go to Solution.
2023-02-08 11:56 AM
indeed 1,2 & 5 🙂
Actually the two wall are interior so two plaster types will be a mess to manage in the quantities (another software).
Hope graphisoft will work in this little issues (coz there many)
2023-02-09 12:11 AM
I manage this problem like this:
# If the two walls 3&4 have the same BM, I'd only duplicate the BM with different (name & cut fill) while keeping priority and all settings the same.
# If the two walls 3&4 have different BM I'd only check that they've the same priority as they already have different cut fills.
Then I split the vertical wall 3 exactly at the reference line of the horizontal wall.
so that's the result.
2023-02-09 08:28 AM
Thank you ,
actually this solution works .
2023-02-09 09:59 AM
I'm happy it worked, thank you.
